AIR Diverter Valve - NCRS Discussion Boards
AIR Diverter Valve
  • Mike R.
    • August 30, 2009
    • 321
    AIR Diverter Valve
    is the diverter valve in the attached picture the correct one for a 1969 L89? If not can anyone post a picture or link to the correct one/
  • John C.
    • January 1, 2005
    • 616
    Re: AIR Diverter Valve
    Mike
    The one in your picture may be the correct valve but it is not mounted correctly. The two links below show cars with the correct mounting of the valve:
    John
      • 43219
      Mike[ATTACH=CONFIG]39975[/ATTACH][ATTACH=CONFIG]39975[/ATTACH]
      Mike-----
      The installed configuration would be correct for an L-36 or L-88 but not for an L-68 or L-71. The latter engines used a special adapter to re-orient the installed position of the valve. The adapter, GM #3955222, is not reproduced, difficult-to-find and expensive if you do find one.
