is this pressed on far enough?
1956 265 balancer
Re: 1956 265 balancer
Cathey:
Its hard to say when these press fit balancers are on all the way, especially from a picture. Here is a picture of a running '60 fuely that shows the vibration damper doesn't always go on as far as you might guess, but it still functions. That being said, please remember in these early years without the bolt, theres a risk of the balancer coming off at speed and wrecking havoc.
1960 fuel inj.jpg- Top
Nope,
Not even close,
If you don't have a threaded crank shaft then you have to do it the old fashon way with a block and a 2lb hammer. The thrust bearing is large and can handle it,
and as the english say on their cars" drive it on home gently with a malet".
You will hear it when it is there but concider tapping your crank and pulling it on as the modern world does.
DOM- Top
In addition to the parts being 50 years old and the press fit, being loose, the 1/8" spacer makes the fit potentially looser. Based on past experience, I will never again put a early motor together without tapping the crank and installing a bolt. As far as the fit in the first picture, because of the spacer, the gap even when the balancer is on may look to wide. Follow Domenic Tallarita's advice.
Regards
- Top
