1972 door handle finish (inside) - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    What finish is on the inside of the door handles on a 1972?
    Is it chrome similar to the outside or is it a frosted silver finish?
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 1972 door handle finish (inside)
    Chrome is correct the frosted silver are later service and reproduction parts.
    • Jerome P.
      • October 22, 2006
      • 607
      Hi Paul
      I found this thread regarding a 1971 car.
      https://www.forums.ncrs.org/showthre...204#post288204
      Was the '71 different then the '72?
      • Paul O.
        • August 31, 1990
        • 1716
        High Jerry
        No they were the same if you have the frosted finished ones you can remove that finish with acetone or lacquer thinner if that helps.
          • 3415
          Hi Jerry,
          I read the mention of 'frost' in the thread you linked, to refer to the fact that the chrome plating in the 'bowl' of the handle wasn't buffed, so it had a 'frosted' appearance compared to the chrome's appearance on the bowl's edge/reveal and the flapper.
          • Paul O.
            • August 31, 1990
            • 1716
            Alan is correct the plating inside the handle was not buffed but it was plated later handles had a silver painted finish applied hence my suggestion to use acetone or lacquer thinner to remove it.
            • Ron G.
              • December 1, 1984
              • 865
              FYI - I believe the handles with the frosted finish inside the handle started in 1974. Could be wrong, but do not think I am.
              "SOLID LIFTERS MATTER"
              • Jerome P.
                • October 22, 2006
                • 607
                Paul/Alan, it appears the bowls have been painted, but the bowls do have a distinct 1/8" of polished chrome on the vertical surfaces. The finish under the paint looks like polished chrome and I am therefore concluding they are service replcements or repo's.Question: I assume on a correct original handle the entire bowl is then a non-buffed chrome finish. Correct?Attached are a couple pix's
                • William M.
                  • July 31, 1993
                  • 390
                  Do what Paul suggests - remove silver paint with lacquer thinner and they'll judge fine. Worked for me on my '73 at Regional and National.
                  Bloomington Gold 2011
                  Corvette Magazine 9/11
                  Bloomington Gold 2013
                  Corvette Magazine 3/13
                    • 3415
                    Hi Jerry,
                    For some reason I'm unable to open your attachment.
                    Here's a picture of the chrome finish on one of the handles from my 71, (46k).
                    The 'lip' is polished and brite, but the entire bowl is unpolished to my eye.
                    • Jerome P.
                      • October 22, 2006
                      • 607
                      Hopefully this will worK.
                      I think under the frosted area of the bowl will be polished chrome and not the unpolished like yours.
                      • Edward J.
                        • September 15, 2008
                        • 6942
                        Jerome, I had a set of GM handles that had the satin finish inside and after the removel of the paint its just like a flash chrome on the inside of handles.
                        • Jerome P.
                          • October 22, 2006
                          • 607
                          Thanks for all the feed back
                          Jerry
