3X2 carb dates- all 3 the same? - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 961
    If my secondary carbs are both dated 782, is it likely that the primary center carb would have the same date code? I know a range of dates would work, but I am curious if generally all 3 would have been the same.
    Pat
  • Dick W.
    • 10483
    Re: 3X2 carb dates- all 3 the same?
    See the dates all over the board on the few originals I have seen.
    Dick Whittington
      • 15646
      Pat
      Most of the originals I see have both ends dated the same, but the center is always different. I would have to do some looking to tell you if the center is earlier or later than the ends, and it may be, as Dick says -- all over the place.
      • Jack C.
        • September 30, 1992
        • 1090
        Patrick. My ends are EU 7A1's and the center is EW 7A4 (Jan 68 build)
        Jack Corso
        1972 Elkhart Green LT-1 Coupe 43,200 miles
        Top Flight 1994, 2018 & 2021
        • Wayne M.
          • March 1, 1980
          • 6414
          Most of the originals I see have both ends dated the same, but the center is always different. .....
          Agree -- here's what's on an original late '69 oval port setup I have:
          ends both 951; center 981.
          • Patrick N.
            • March 10, 2008
            • 961
            Thanks Guys, I ask because I have a center carb that is the wrong date code and not sure I want to chase a correct one. what is the deduction I should expect for the following center carb: 3940929-EV
            List-4055-1, 001?
            I have researched other threads that suggest 3 month window on center carb vs. secondaries- would you still agree?
            • Mark D.
              1984-96 Team Leader
              • June 30, 1988
              • 2179
              Not that you asked but, the gaskets in the pic will take a minor deduction.
              Kramden
              • Ralph S.
                • February 1, 1985
                • 935
                My 1969 435hp car build Q11 12/11/69 front & rear are 993 center is 992 i'm kind of rusty on the date codes what do they translate to?
                • Mark D.
                  1984-96 Team Leader
                  • June 30, 1988
                  • 2179
                  I think it's the 993rd day of the year, or it could be 1969, ninth month, third week (and second week)
                  Kramden
                  • Paul O.
                    • August 31, 1990
                    • 1716
                    Donnally
                    You are one smart fella and a wise guy.
                    • Patrick N.
                      • March 10, 2008
                      • 961
                      Yes, thanks or the catch, this was one of my rookie mistakes. Now i have what I think is the right one- cork with bits of rubber in both a darker and lighter variation. Some say light, some say dark- I have both now, with the light one in place- Crazy, right?
                      Best,
                      Pat
                      • Mark D.
                        1984-96 Team Leader
                        • June 30, 1988
                        • 2179
                        Kramden
                        • Pat M.
                          • April 1, 2006
                          • 1588
                          Crazy, right?
                          That could be our new motto: NCRS - Crazy, right?
