70 timing tab pic needed - NCRS Discussion Boards
  • Steve F.
    Infrequent User
    • October 21, 2010
    • 25
    I have looked everywhere including a search of this forum for a picture of a correct timing cover and tab for a 70 LT-1. I believe all 70 SB used the same cover as they all had the 8 inch balancer. I have found most years but nothing definitive on the 70 tab. Could someone post a picture of what you know to be a correct 70 cover and tab?
    • 43293
    Re: 70 timing tab pic needed
    Steve------
    Do you have a photo of a 1969 Corvette small block timing tab? 1969 is the same as 1970.
      • 3422
      Hi Steve,
      The Fourth Edition of the 70-72 TIM/JG has a photo that shows both the 70 and 71-72 tabs.
      It's not a real clear picture, but may be enough to help you to know what to look for.
      • Ron G.
        • December 1, 1984
        • 866
        I do not have a picture, but I do know 68 thru 70 is one configuration and that 71 & 72 are another. Also. I am of the opinion that they were painted orange as they were installed on the engine when painted at Flint.
        - Ron
          • 11698
          - Ron
          I'm of the opinion that they were either taped off or wiped off.
          • Steve F.
            Infrequent User
            • October 21, 2010
            • 25
            Reading above I think you can see why I continue to be confused. I believe I currently have a 68 and it looks quite different then any other photo I have seen of what is said to be a 69/70 as it is long and extends over the edge of the cover. I have read where they were changed in 69 through 70 and then again in 71?
            Patrick, is this a picture of a 70 as it looks nothing like any other information I have seen. I do not have access to the books mentioned although I have many books on the C3 and have purchased a few here.
            I have seen several conflicting photo's and was hoping to get a definitive answer here - does anyone have a 70 that can post a photo or if Patrick has already done so, thank you and I need to start a whole new search.
            • David L.
              • July 31, 1980
              • 3310
              Pictured below is a 69-70 Camaro timing cover with 8" balancer. The covers have a stamped date code.
              Dave
                • 11698
                1972 - I was only showing it for color (or lack thereof), not configuration.
                • Pat M.
                  • April 1, 2006
                  • 1588
                  The tab on my 70 SB looks like the one shown by Dave:
                  • Ron G.
                    • December 1, 1984
                    • 866
                    Pat,
                    That photo looks to be the correct configuration for a 68 thru 70.
                    - Ron
                    • Pat M.
                      • April 1, 2006
                      • 1588
                      Pat,
                      - Ron
                      Thanks Ron, I thought so, but it's good to hear someone else say so.
                        • 43293
                        All------
                        Attached is a photo of a guaranteed original late 1969 small block timing tab. I believe this same tab was used for 1970. I'm not so sure about 1968, though. If it was used, it was used only for L-79 inasmuch as the 1968 base engine used a ~6" balancer.
                        By the way, ALL 1969-70 350 CID small blocks with 4 barrel carburetor used 8" balancers and the pictured timing tab. This includes Corvettes and all other Chevrolet models as well.DSCN2690.jpg
                        • Steve F.
                          Infrequent User
                          • October 21, 2010
                          • 25
                          Thanks that is just what I needed.
                          I can start another thread unless someone happens to get this next question - What is the width of a 8" balancer for a 70 LT-1?
                            • 43293
                            Steve------
                            1-11/16"
                            • Steve F.
                              Infrequent User
                              • October 21, 2010
                              • 25
                              Thanks Joe, thats what I thought. I have two with one being less wide and I wanted to be 100%.
                              Thanks to all for the help.
