DOM, Received your Message, Cannot Respond - NCRS Discussion Boards
  • Joe R.
    • July 31, 1976
    • 4552
    DOM, received your PM and tried to respond several times. Having trouble with this new system (do you hear this administrator, this new system is trash).
    Anyway send me a message via my e-mail: vettenut0071946@att.net
    I will respond as I have tried on this (system). Trying to be nice now!
    JR
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: DOM, Received your Message, Cannot Respond
    Joe,
    Thanks, it took me a while to figure out how to send the message also.
    Joe, I needed the worm gear that the speedo cable drives because it was warn.
    I found it while I was doing my cluster (1967).
    Dick W said you were the guy to do them but I also repaired speedo's when they were gear driven and do every thing inhouse.
    Amazing how good these work once you clean the old hard grease and replace it with a good lube.
    Peter H told me where to get the gear and it was only $11.95.
    Corvette central had it and it made sence that that would be the gear to wear out first as it drives all the odometer & trip.
    Thanks for responding.
    DOM
    • Joe R.
      • July 31, 1976
      • 4552
      DOM,
      You will also need the #2 gear as it usually wears out first. But here's your problem. The #1 gear is the one that is magnetized and calibrated to work with your speed cup.
      You will need to take it to a speedometer shop and get them to calibrate after installing the two gears.
      Without it being magnetized and calibrated it will just sit on the peg.
      JR
