Corvette trailer question - NCRS Discussion Boards
  • Patrick S.
    • January 1, 1988
    • 209
    I AM PUTTING A WINCH IN MY ENCLOSED TRAILER SO I CAN "DRAG" THE VETTE INTO POSITION. WHEN I HAD THE COBRA I COULD JUST DRIVE IT IN AND HOP IN AND OUT, BUT I CAN'T DO THAT WITH THE VETTE.
    MY QUESTION IS ABOUT THE WINCH WIRING. I PUT THE BATTERY TO OPERATE THE WINCH BY THE CONTROLLER AND WANT IT TO CHARGE WHILE THE TRAILER IS HOOKED TO THE TRUCK. IF I JUST TAP INTO THE MAIN POWER FROM THE TRUCK, WILL IT CHARGE THE BATTERY ??
    PAT (12382)
  • Michael G.
    • November 12, 2008
    • 2158
    Re: Corvette trailer question
    Mine does. Powers the whole trailer, lights, winch, alarm. Been that way two years. Once, the truck had to charge a fully discharged trailer battery while I drove. Did fine.
    An alarm installer hooked it up, though, so I can't tell you the exact wiring scheme.
    Before you do it, you might want to wait for a comment from someone who knows something about auto electric systems
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • Dick W.
      • 10483
      If your truck came with a tow package, chances are there is a battery charge wire in the harness. I cannot remember which makes you have to add a fuse or jumper wire to so that it will work. I will look tomorrow.
      Dick Whittington
      • Patrick S.
        • January 1, 1988
        • 209
        My tow truck is a GMC Vortex Max with a full towing package.
        • Dick W.
          • 10483
          Attached is a standard 7 way Bargman plug wiring diagram. Number 4 connector is for charging
          Dick Whittington
          • Stephen L.
            • May 31, 1984
            • 3162
            Here is a wiring diagram to hook up all wiring including the brakes to your new battery.
            I added a light on the front of the trailer near the hitch to indicate that the breakaway switch is operational when the plunger has been pulled out.
            I eliminated the small battery that came with the trailer for the brake system emergency activation.
            • Patrick S.
              • January 1, 1988
              • 209
              Got just what I need.
              Pat
