'67 Drivers side door opening Knob. - NCRS Discussion Boards
  • Herb E.
    • August 21, 2011
    • 47
    Has anyone experienced this problem? I locked the doors, and later opened them with the key. Once back inside the car I attempted to get out by pulling back the Door opener (Ball). Nothing happens, it just moves back and forth. I have to use the outside push button to open the door. This has happened several times, and only after first locking the door. Does anyone know what's causing this and how to fix it? Thank you...Herb Evans
  • Tom D.
    • September 30, 1981
    • 2145
    Re: '67 Drivers side door opening Knob.
    Connecting latch rod fell off inside the door? But then it would not recover, which is sounds like yours does...
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Michael M.
      • February 1, 1993
      • 606
      Herb, I have never had this problem on a corvette but have experienced the problem on other GM cars. It sounds like the rod that actuates the inside door opener is not connected. To find out for sure you have to take the interior door panel off.
      • Bill H.
        • August 8, 2011
        • 439
        Agreed, it could be the rod.
        Also, I have latches out of my doors right now, the greese was so gummed up that the inside lever would not move far enough to release the star wheel.
        • Gary S.
          Super Moderator
          • February 1, 1984
          • 460
          Before you take the door panel off, try turning the inside lock knob to the full lock position then to the full unlock position.
          Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
          • Domenic T.
            • January 29, 2010
            • 2452
            Herb,
            I just put my 67 doors together after taking everything out of them and it sounds like you need to adjust the rod.
            They have bends in them that straighten out or just get worn alittle (hole).
            You can tighten them by increasing the bend if that's the problem.
            DOM
