Leaf Spring Stiffness 4- vs 5-leaf - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    Since I drive my '60, I'd like stiffer springs on the back. I put on some wider radial tires for better rain traction and now they rub over bumps. Before I take them off, I'd like to try stiffer springs.
    I was thinking of purchasing a pair of the repro five leaf springs, but I was wondering how much stiffer they are than the four leaf? Or is there an aftermarket spring that would be stiffer?
    Bob
  • John F.
    • March 23, 2008
    • 2414
    Re: Leaf Spring Stiffness 4- vs 5-leaf
    Air shocks will take care of it!
    • Peter V.
      • June 2, 2008
      • 116
      What John said!!
      • Al E.
        • September 5, 2011
        • 313
        I would go with a dial-in shock that way you can adjust to your likeness and it is much cheaper..
        But what do I know...
        Al
        • Steven B.
          • June 30, 1982
          • 3998
          Bob, I installed a quick steering adapter and an extra leaf (totalling 5) on my '57 in 1965 to raise the rear for my 7.75's and offset 6" wheels (California rake ). I also autocrossed it. The extra leaves are still on it and I don't mind the ride but it is very hard and 99% of drivers would not like it. If you add the leaf be certain to have good seat belts and be prepared to bounce around a bit.
          Steve
          • Bill M.
            • April 1, 1977
            • 1386
            That's what I did.
