65 Powered Antenna - NCRS Discussion Boards
65 Powered Antenna
  • Michael M.
    • June 5, 2011
    • 30
    65 Powered Antenna
    How many total sections should there be?
    How high when totally extended?
    How short when retracted?
    Any pics of your antenna would be appreciated.
    Thank you,
    Mike (53411)
  • Clark K.
    • January 12, 2009
    • 536
    Re: 65 Powered Antenna
    Mike, the 1965 power antenna is something that I have been fussing with for a few months. I had a repro one on my car when I bought it three years ago and I have installed a rebuilt original in order to recover 7 originality points.
    Here is what the 1965 JG has to say: "...consists of four stainless steel telescoping sections, with a dart shaped tip at the top. The three outside sections of the mast have an indented ring (relief cut) a full 360 degrees and approximately 1/2" down from their top edge. The height in the lowered position is approximately 13-1/2"; however, this varies slightly from car to car.".
    I have attached a photo of the extended antenna. The height of my unit is 51" from the tip to the fiberglass body (including the nut).
    -Clark
    • Michael M.
      • June 5, 2011
      • 30
      -Clark
      Thank you very much for the help. I must not have an original as it has 3 sections and no dart for a tip!
