Good Year Run Flats
Re: Good Year Run Flats
i talked to the people at slime and they said only use it as a temporary fix. clean the tire and wheel out with water and do a proper inside repair. remove the core and rinse out the tire valve with the sensor on it. till you clean it it may not read correctly but after cleaning it should work fine. they said if you can prove it damaged the sensor they will replace it.- Top
