Good Year Run Flats - NCRS Discussion Boards
Good Year Run Flats
    • 15610
    Re: Good Year Run Flats
    Terry,
    Do you have the Michelin PS2 ZP model (which is a run flat) or the AS plus ZP. ???? The PS2's are more expensive than the AS plus but a quite a bit less than the Goodyear run flats.
    Pretty sure they are the PS2 ZP -- they are run flats. I don't have the courage to go with non-run flats given the mileage I rack up going to NCRS events and Road Tours.
      • 15610
      Originally posted by Harry Sadlock (38513)
      I spoke with the Corvette mechanic at the local dealership today. I do not know if this is true but this is what he said.
      All new Corvettes are setup and wheels aligned for racing. Meaning, lots of cornering. The result is excessive tire wear. He said to have the car aligned for normal street driving and this will significantly extent tire life.
      Can anyone comment on this?
      I agree with Clem, and that is backed up by Tom Hill, BG Quality Engineer (or some title close to that). Tom told us (the Advanced Judging Seminar) in Florida several times that the alignment is set up for cornering and not street driving. He said the same thing in 2010 to the same audience at the National in North Carolina. They (the Corvette Engineering Team) believe most Corvette owners will drive their car in a manner that compliments the more aggressive alignment. Those of us who do long distance highway travel are out of luck, so far.
      • Bill C.
        • June 25, 2007
        • 106
        #18
        Based on a previous thread, I took my new 09 C6 to the dealer to have it aligned.
        If I remember correctly, the alignment tech showed me the GM computer screen. It had specs for "touring". I had my alignment changed to that.
        Thanks for the advise guys.
        Bill
        • Joseph S.
          National Judging Chairman
          • March 1, 1985
          • 885
          #19
          2007 Z06, I stretched the first set of tires out to 15K miles. Rears weren't as bad as the fronts but all 4 were done! Fronts had the wire brush look on the first 3" of inside tread!!! Next 2 sets of tires didn't last any longer either. I will switch to Nittos for next set and see if they are any better.
          Thanks to everyone who gave me the excuse that it is the alignment and not my driving habits!!
          • Clem Z.
            • January 1, 2006
            • 9427
            #20
            i have seen the steel belts showing on the inside edge at 6000 miles and the rest of the tire was hardly worn.
            • Deane M.
              • January 2, 2007
              • 143
              #21
              Just want to thank all you guys. Great feedback, info. and advice for moving forward. Car is not driven aggressively 98% of the time. Will aligin accordingly and go from there.
              Thanks!
              • Harry S.
                • July 31, 2002
                • 5330
                #22
                Went to the local Chevy Dealership today. They spent almost two hours aligning the front and rear. I was pleased it cost $85.00.
                Tire life should be much better now!
                • Vinnie P.
                  Editor NCRS Restorer Magazine
                  • May 31, 1990
                  • 1571
                  #23
                  Harry...do you know what the specs were for your alignment? Here are the recommended factory specs for the different suspensions. Do you know if they used any of these?
                  • Harry S.
                    • July 31, 2002
                    • 5330
                    #24
                    Here is where we started:
                    Front Camber -0.8 -0.8
                    Caster 7.6 7.0
                    Toe -0.01 -0.03
                    Here is where we ended:
                    Camber -0.2 -0.1
                    Caster 7.8 8.0
                    toe 0.05 0.04
                    Rear Start
                    Camber -0.5 -0.6
                    Toe -0.15 0.01
                    Total toe -0.14 -0.08
                    Rear ended
                    camber -0.5 -0.6
                    toe 0.00 -0.01
                    Total toe -0.01 0.00
                    • Tom H.
                      • December 1, 1993
                      • 3440
                      #25
                      Confirmed fact.
                      Tom Hendricks
                      Proud Member NCRS #23758
                      NCM Founding Member # 1143
                      • Deane M.
                        • January 2, 2007
                        • 143
                        #26
                        Thanks Harry and Vinnie. New tires on car (Nitto Invo's) Doing alignment early next week. Great to have these specs. Vinnie, you mentioned carrying a "fix a flat" type product. How would that effect the tire pressure sensor if used? Any idea. Let me know.
                        Thanks.
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          #27
                          Thanks.
                          the fix a flat will ruin the tire pressure sensors.
                          • Vinnie P.
                            • May 31, 1990
                            • 1571
                            #28
                            Deane...the Slime yellow label sealants are supposed to work just fine with tpms sensors...but I'm not an expert and have no experience with using it yet...website also says it can be washed out with water after the tire is broken down to repair the tire from the inside...
                            From the Slime website
                            Does your vehicle have a TPMS (Tire Pressure Monitoring System)? Use our yellow label sealants with the TPMS Safe icon. They are specially designed for use in tires with these systems.
                            • Clem Z.
                              • January 1, 2006
                              • 9427
                              #29
                              interesting as a lot of corvette owners will be interested in this. i will call them today and see what they say. reading their website it looks like you put the stuff in before you have a flat. it is not clear to me that it goes in thru the tire valve but put in before the tire is mounted
                              • Deane M.
                                • January 2, 2007
                                • 143
                                #30
                                Their website also states "not for use in tires mounted on chrome wheels" or "may not be good for....." Vinnie and Clem, thanks for the follow up.
