I am assembling a 7017375 unit. Does the gasket go above or below the main control diaphragm? I can't find it in any of my books. I assume above but want to be sure. Thanks, Don H.
FI Main Control Diaphragm
Re: FI Main Control Diaphragm
Goes above the diaphram to seal the vacuum signal. Originals gaskets were marked for the top side due to a sharp edge on the that side that would have cut into the the original silk/rubber diaphrams thin skin. Repro diaphrams are made of rubber now, tougher I guess. Make sure the top cover is totally flat for a good seal.
Dan1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
Thanks Dan, that is what I thought. I have wondered why don't they use a gasket on the enrichment diaphragm? I do surface all housings with a granite surface plate. Recently I found an original gasket in my parts that was marked as you mentioned but it was very old and curled. The new kits are very nice. Thanks again, Don H.- Top
shrunk paper gasket can be brought back to life by soaking them in hot water. i have to do that with older carb kitsThanks Dan, that is what I thought. I have wondered why don't they use a gasket on the enrichment diaphragm? I do surface all housings with a granite surface plate. Recently I found an original gasket in my parts that was marked as you mentioned but it was very old and curled. The new kits are very nice. Thanks again, Don H.- Top
A minor leak at the enrichment diaphragm doesn't cause major problems.
The main diaphragm is subject to more subtle vacuum levels than the enrichment diaphragm. As such, a vacuum leak at the main diaphragm would be disruptive so it needs better sealing.
Jim- Top
