FI Main Control Diaphragm - NCRS Discussion Boards
  • Don H.
    • December 1, 1981
    • 1491
    I am assembling a 7017375 unit. Does the gasket go above or below the main control diaphragm? I can't find it in any of my books. I assume above but want to be sure. Thanks, Don H.
  • Dan H.
    • July 31, 1977
    • 1369
    Re: FI Main Control Diaphragm
    Goes above the diaphram to seal the vacuum signal. Originals gaskets were marked for the top side due to a sharp edge on the that side that would have cut into the the original silk/rubber diaphrams thin skin. Repro diaphrams are made of rubber now, tougher I guess. Make sure the top cover is totally flat for a good seal.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Don H.
      • December 1, 1981
      • 1491
      Thanks Dan, that is what I thought. I have wondered why don't they use a gasket on the enrichment diaphragm? I do surface all housings with a granite surface plate. Recently I found an original gasket in my parts that was marked as you mentioned but it was very old and curled. The new kits are very nice. Thanks again, Don H.
      • Clem Z.
        • January 1, 2006
        • 9427
        shrunk paper gasket can be brought back to life by soaking them in hot water. i have to do that with older carb kits
        • Jim L.
          • September 30, 1979
          • 1816
          A minor leak at the enrichment diaphragm doesn't cause major problems.
          The main diaphragm is subject to more subtle vacuum levels than the enrichment diaphragm. As such, a vacuum leak at the main diaphragm would be disruptive so it needs better sealing.
          Jim
