1957 engine - NCRS Discussion Boards
1957 engine
  • Michael J.
    • January 27, 2009
    • 7166
    1957 engine
    I found a 1957 dual quad engine for sale, but it has a F425EB stamp on the pad. What is that from? Thanks for any tips.
  • Michael W.
    • April 1, 1997
    • 4290
    Re: 1957 engine
    EB 67 327 Chevelle 275 L-30 Manual 4-BrlHyd Cam, A.I.R.
    • Michael J.
      • January 27, 2009
      • 7166
      Re: 1957 engine
      OK, thanks, very interesting, not even a '57! Kind of misrepresented.
      • John S.
        • July 29, 2009
        • 640
        Re: 1957 engine
        EB is a 57 engine code. it is a 283 w 2-4 bbl carb +hi lift cam. it is not found on a corvette.
        • Michael J.
          • January 27, 2009
          • 7166
          Re: 1957 engine
          Originally posted by John Scopelite (50653)
          EB is a 57 engine code. it is a 283 w 2-4 bbl carb + lift cam. it is not found on a corvette.
          OK, thanks very much for the info, not a fraud after all.
          • Michael W.
            • April 1, 1997
            • 4290
            Re: 1957 engine
            Found some more
            EB 55 265 Truck 15 422 1 Manual2-Brl
            EB 57 283 Impala 270 469C 3-spd 2 4-Brl Carter WCFB, HP solid cam
            EB
            58 283 Impala 230 410 Power glide4-Brl
            EB
            59 283 Impala 230 410 Power glide 4-Brl
            EB
            60 283 Impala 230 410 Power glide 4-Brl
            EB
            61 283 Impala 230 410 Power glide 4-Brl
            EB
            65 327 Chevelle 300 L-74 Manual 4-Brl Hyd Cam, AFB
            EB 66 327 Chevelle 275 L-30 Manual 4-Brl Hyd Cam, AFB, A.I.R.
            • John S.
              • July 29, 2009
              • 640
              Re: 1957 engine
              Found some more
              EB
              EB
              EB
              EB
              EB
              it is not necessary to list all the different years that EB is used. F425EB will only be found on a 57 block pad. the other years have different arrangement of pad numbers.
              • Bruce B.
                • May 31, 1996
                • 2930
                Re: 1957 engine
                OK, so please explain the other arrangements.
                • Jim L.
                  • September 30, 1979
                  • 1817
                  Re: 1957 engine
                  No such animal.
                  Top of the line in '57 was the Bel Air.
                  Also, '57 passenger car engine codes weren't specific to the trim lines. An EB engine could have gone into a 150, 210, or a Bel Air.
                  • John S.
                    • July 29, 2009
                    • 640
                    Re: 1957 engine
                    No such animal.
                    in 1957 , what was the transmission used with the EB motor?
                    • Michael W.
                      • April 1, 1997
                      • 4290
                      Re: 1957 engine
                      I'd like to know too.
                      • Jim L.
                        • 1817
                        Re: 1957 engine
                        3 speed, non-overdrive. All solid lifter engines, such as the "EB" suffix came with manual transmissions.
                        • Bruce B.
                          • May 31, 1996
                          • 2930
                          Re: 1957 engine
                          3 speed in pass car as noted by Jim L.
                          • John S.
                            • July 29, 2009
                            • 640
                            Re: 1957 engine
                            pre 57 cars had 7 digit engine sequence numbers on the pad and mid sixty EB pads were showing partial vin#. i did not include any late 50 or early 60 EB engines because none had the dual quads that mike mentioned.
                            • John N.
                              • February 1, 1975
                              • 451
                              Re: 1957 engine
                              Most if not all were 3 speed close ratio with 3.55 rear end from the factory.
