69 BB front springs - NCRS Discussion Boards
69 BB front springs
  • Phillip G.
    • April 30, 1992
    • 42
    69 BB front springs
    I'm in the process of restorating a 69 BB coupe. In searching for new front springs all I can find are reproductions that are painted black. If I can not find orginials, how many points will be lost in judging do to the non natural finish?
    • 6950
    Re: 69 BB front springs
    Phil, just remove the paint from the springs. and if you don't like the rusting problem,use a couple of coats of satin clear paint. and that as close as you'll get to natural.
    • Phillip G.
      • April 30, 1992
      • 42
      Ed, thanks, but I believe its powder coating. I have used the clear on my other cars with great success.
      • G A.
        • February 18, 2010
        • 229
        I just went through this on a '69 BB convertible.
        Volunteer Vettes has a set they list as 'exact' (yeah, I know) reproductions. The appearance is flawless, heat treated blue steel. The number of coils, wire diameter, and all that other stuff was right based on the spring data I found. They are in the car and look like the installed height will work out nice. The springs are the variable rate style and are somewhat of a bear to install, but I think they will be great.
        Dan
        • Phillip G.
          • April 30, 1992
          • 42
          Dan, thanks, I'll check them out. Their online page says they only have SB springs?
          • G A.
            • February 18, 2010
            • 229
            Their part number is SU12H.
            Dan
            • Phillip G.
              • April 30, 1992
              • 42
              If your front end height is correct, I'll probably go with them. The 69 Judge told me the black springs are a 2 point deduct. Thanks for your help!!
