neg btry cable - NCRS Discussion Boards
neg btry cable
  • Mike S.
    • August 21, 2011
    • 57
    neg btry cable
    Could any one advise me where the braided negative post battery cable is to go for grounding. My cable is 17" overall lenth. Mike
    PS, my car is a 1963 convertable, 327 ci, 300 HP
    • 43277
    Re: neg btry cable
    Mike-----
    I believe the negative battery cable terminal installs under the outside (short) starter motor attachment bolt.
    • Mike S.
      • August 21, 2011
      • 57
      Re: neg btry cable
      Joe
      Thanks for the info, and that is where I thought but my cable is not long enough.
        • 43277
        Re: neg btry cable
        Joe
        Mike-----
        You have the wrong cable. First of all, the original cable used was not braided; it was insulated cable. Second, the cable should be 25" center-to-center in length.
        • Gary C.
          • March 1, 1998
          • 236
          Re: neg btry cable
          Mike
          The braided cable is for a 63 with C60 A/C. It would ground on the left side front exhaust manifold IIRC.
          • Mike S.
            • August 21, 2011
            • 57
            Re: neg btry cable
            Gary
            My 63 does have the A/C, I did not mention before. When you refer to the front of the exhaust manifold you mean radiator, correct?
              • 43277
              Re: neg btry cable
              Gary
              Mike-----
              Now that surprises me. I was assuming that you were talking about a non-AC car. There were very few 1963 Corvettes built with AC and, likely, a very small number of convertibles. Also, I was not aware that AC cars used the braided-type negative battery cable but I learn something every day.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11364
                Re: neg btry cable
                Photos of a 63 convertible with A/C showing the ground strap.
                • Mike S.
                  • August 21, 2011
                  • 57
                  Re: neg btry cable
                  Richard
                  Thank you very much. These pictures help a lot and I am very appreciative of your taking the time to send them. Mike
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11364
                    Re: neg btry cable
                    You're welcome Mike.....I saw that '63 about a year ago and took many pictures. I'm pretty sure the ground strap is original to the car.
                    It's a 300HP, with PG auto trans, PW, PS. Been sitting outside under a cover here in Florida since 2004.
                    Rich
                    • Mike S.
                      • August 21, 2011
                      • 57
                      Re: neg btry cable
                      Richard
                      Amazing, that she has sit for so long. Is it for sale? Mike
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11364
                        Re: neg btry cable
                        Nope, won't sell. He had a fuelie SWC, and this convertible was his wife's car since the 70's. He sold the SWC years ago but kept this one. He started taking it apart years ago in his back garage. When the hurricanes came in '04, he pulled it out of there because the water was rising. He brought it out front to higher ground, covered it up, then he got ill. He knows it's getting worse daily but doesn't want to part with it.
                        • Mike S.
                          • August 21, 2011
                          • 57
                          Re: neg btry cable
                          Richard
                          Too bad. Dont know if current market trends will overcome the daily deteroration, but each to his own. Again thanks for the pics, always enjoy looking at these cars. Mike
                            Re: neg btry cable
                            Here's another photo of a '63 A/C negative cable.
                            • Mike S.
                              • August 21, 2011
                              • 57
                              Re: neg btry cable
                              John
                              Thanks this is a great picture. One question did they put the battery on both sides. My battery is located on the passenger side of the car, just forward of the firewall tucked into the right front fender well.
