I'm replacing a dashpad on a late March built 1959. The 1959 AIM shows the later flat screen with the bezel. I know there is no bezel on the 1958 & most 1959's.
I have installed the 4 Tee bolts in the dash, attached with resin to keep them in place for the speaker to attach from under the dash. The 58/59 screen has four holes. I am under the understanding that the screen sits on TOP of the dash and protrudes through the dashpad so that it sits basically flush with the dashpad on top......correct? Reference thread with photos.....https://www.forums.ncrs.org/showthre...071#post467071
Can someone show the page in the 1958 AIM which clearly shows the proper screen installation?
It's also a bit confusing why the screen would have four holes in it, when nothing will go through them if it's installed between the dash top and the pad. If I place the screen UNDER the dash, up through the 4 Tee bolts, it sits very low under the pad. This thread says that's the way the screen mounts but?????
https://www.forums.ncrs.org/showthre...eaker-Question
Rich
Rich
