63 Gas Cap question - NCRS Discussion Boards
63 Gas Cap question
  • Edward J.
    • September 15, 2008
    • 6950
    63 Gas Cap question
    I have my original gas cap, but no gasket on it, were the originals a cork or paper gasket. are they reproduced?
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 63 Gas Cap question
    Current judging manual states a thick paper gasket was used.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Edward J.
      • 6950
      Thanks Tom
      • Stuart F.
        • August 31, 1996
        • 4676
        My original (19,xxx) has a thick paper type gasket. I don't use it anymore due to the single vent hole design (when using ethanol laced fuel), rather for every day I use the later design with the two way valve (vacuum/pressure) that is still available as a service replacement, or my locking cap for mixed car shows.
        Stu Fox
          Ed -
          Long Island has the fiberboard/paper gasket, so does Paragon.
          • Peter L.
            • May 31, 1983
            • 1930
            FYI. My experience is that the LI gasket (I don't know about Paragon's) is ~9/32" wide and fills up the entire groove of the gas cap while the original gaskets were ~7/32" - 8/32" wide and did not completely fill the groove of the gas cap. Picky, picky, picky but that's what separates a "reproduction" from the "real deal" or an "exact reproduction." You don't gotta go the extra 1/32". You gotta love this hobby. Pete
            • Tom D.
              • September 30, 1981
              • 2137
              You know the reproductions are always a little off, just to keep it interesting...
              https://MichiganNCRS.org
              Michigan Chapter
              Tom Dingman
              • Andy C.
                • May 31, 1987
                • 71
                The original gaskets were brown paper and look smaller than the reproduction from Long Island because from age they have shrunk a bit.....
                • Peter L.
                  • May 31, 1983
                  • 1930
                  Andy - Interesting. Personally, I don't think so. How long do we have to wait for them to age and shrink and look like an original? Pete
                  • Rob M.
                    NCRS IT Developer
                    • January 1, 2004
                    • 12799
                    15 minutes with a heat gun ;-)
                    Rob.
                    NCRS Software Developer
                    • Matt L.
                      • February 23, 2010
                      • 337
                      Stu Fox
                      hi Stuart, why is it different with ethanol? is it because of the fast evaporation if it sits in the tank? and i can see why for the locking gas cap.
                      take care,
                      matt
                      • Peter L.
                        • May 31, 1983
                        • 1930
                        Neat trick.
                        • Larry M.
                          • January 1, 1992
                          • 2701
                          Try DR REBUILD. #3028-201 I think you will be happy.
                          Larry
