I have my original gas cap, but no gasket on it, were the originals a cork or paper gasket. are they reproduced?
63 Gas Cap question
Re: 63 Gas Cap question
My original (19,xxx) has a thick paper type gasket. I don't use it anymore due to the single vent hole design (when using ethanol laced fuel), rather for every day I use the later design with the two way valve (vacuum/pressure) that is still available as a service replacement, or my locking cap for mixed car shows.
Stu Fox- Top
- Top
FYI. My experience is that the LI gasket (I don't know about Paragon's) is ~9/32" wide and fills up the entire groove of the gas cap while the original gaskets were ~7/32" - 8/32" wide and did not completely fill the groove of the gas cap. Picky, picky, picky but that's what separates a "reproduction" from the "real deal" or an "exact reproduction." You don't gotta go the extra 1/32". You gotta love this hobby. Pete- Top
Rob.
NCRS Software Developer
C1, C2 and C3 Registry Developer- Top
hi Stuart, why is it different with ethanol? is it because of the fast evaporation if it sits in the tank? and i can see why for the locking gas cap.My original (19,xxx) has a thick paper type gasket. I don't use it anymore due to the single vent hole design (when using ethanol laced fuel), rather for every day I use the later design with the two way valve (vacuum/pressure) that is still available as a service replacement, or my locking cap for mixed car shows.
Stu Fox
take care,
matt- Top
Pete
