Tri-Power Carb Mounting Gaskets - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    A few years ago I ordered replacement carb gaskets from Paragon. I just noticed that they had one gasket labeled "Center Carb, This side up". Am I missing something that the Center Carb gasket was different from the two ends?
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Tri-Power Carb Mounting Gaskets
    the gasket has to cover the external vacuum passage under the carb and if installed up side down you will have a vacuum leak
    • Clem Z.
      • January 1, 2006
      • 9427
      here is a picture of the problem
      • Jack C.
        • 1090
        Thanks Clem.
        Jack Corso
        • Wayne M.
          • March 1, 1980
          • 6414
          Hey Clem -- I click on your thumbnail and nothing expands.
          Jack and others --- (starting ?) at beginning of 1968 production, [per Aug '67 Corvette Service News] the plant used thinner tripower carb-to-manifold gaskets, replacing the thicker material used in the 1967 MY L68, L71 and L89's, and which caused sticky secondary carb throttle shafts due to over-torquing the carb nuts and unevenly compressing the thick carb gasket.
          These new gaskets were identified by following lettering: "this side up END carburetors" and "this side up CENTER carburetors". I don't know what the '67 and '68 TIM&JG's say about this, but a sharp eye should be able to tell which thickness is used (or should be present for TFP) on the '67's.
          • Jack C.
            • 1090
            Thanks Wayne. It looks like I have the correct ones. I always thought the 3 were identical and was very aware on how they mount on each carb mount on the intake. I have been trying to diagnose a "vapor lock" like problem for quite sometime and was wondering if the carb gaskets I used prevoiusly might be giving me this problem. Lord knows I have looked at everything else. The car would start and run fine that after a longer run would die out at idle. I would have to wait 15 or 20 minutes and it would then start. It would crank fine but not fire up.
            Jack Corso
            • Clem Z.
              • January 1, 2006
              • 9427
              must be on your end check your computer settings. go to "view" and go down to "zoom" and select 200%
                • 15601
                I doubt it is just Wayne's computer. Mine has been doing the same thing, and yet the post about the 7-pound radiator cap is OK -- I can expand that photo just fine. In the last few days something has changed with the type of photo posted or this site. I will check from work tomorrow and see if the same thing happens there.
                • Joel F.
                  • April 30, 2004
                  • 659
                  you're not alone Terry and others ... I can't blow up this photo either but can on some of the other links. I wonder if a setting was changed accidently by the forum admin?
                    That photo won't expand for me either (Windows 7, IE9).
                      • 15601
                      I am on Windows XP and Firefox 11.0
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        i tried it on a different computer here and going to page and zoom 200% it get larger
                          Clem -
                          I can zoom it also (Ctrl-scroll wheel), but it doesn't enlarge when you click on it. If you right-click on it and then click Properties, it's only 2520K, 100x72.
