big block valve wsprings - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: big block valve wsprings
    F/M lists a valve spring VS1581 that looks close
    • Keith B.
      • March 7, 2008
      • 928
      what are the valve springs used on the new Chevy BB crate engines
        • 15706
        #18
        The napaonline.com buyer's guide lists it for use on what looks like all big blocks from '65 into the seventies, so it appears to be an OE replacement, but unfortunately no force/rate data is listed for it.
        Someone will have to buy one and have it tested to be sure.
        It's a dual spring with a damper sandwiched between the two springs... interesting.
        • Clem Z.
          • January 1, 2006
          • 9427
          #19
          105#@1.880, 370 #/inch
          • Clem Z.
            • January 1, 2006
            • 9427
            #20
            here you go on the valve springs. zoom to 200% and you can read the page
              • 15706
              #21
              I can't read all the data regardless of magnfication. Some it too blurred. Can you write it out?
              • Jerry G.
                • April 1, 1985
                • 1022
                #22
                Clem
                What about a modern Beehive spring for this appilcation? GM likes them now in their HP motors? Jerry
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  #23
                  VS1581,dual spring/damper ,OD 1.460, max lift .620, closed pressure 105#@1.880, coil bind 1.200, #/inch 370, open pressure 338@1.250
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    #24
                    Originally posted by Jerry Gollnick (8575)
                    Clem
                    they should work but i am not sure of what is available
                    • William F.
                      • June 9, 2009
                      • 1364
                      #25
                      If I replace the first desing valve springs, seals, locks, should I replace other components such as new (GM or aftermarket such as Lunati) pushrods, rocker arms, etc.?
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        #26
                        also if you use the spring with the flat wound damper make sure the valve spring shim you use is hardened as these flat wound damper will cut into any metal that is not hardened. you can use a file to check to make sure the shims are hardened and the ones sold by GM are hardened
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          #27
                          no if they show no sighs of wear. also keep the parts together as they come out of the engine so there is no breakin required.
                          • Wayne M.
                            • March 1, 1980
                            • 6414
                            #28
                            From How-to-Hotrod BB Chev's (1972 issue); they only concern themselves with hi-perf GM items.
                            There was another 396/427 spring (not shown) #3856860 (w/damper) for Passenger BB's (exc. Sp. H/Per.) starting in '65 and covering all low-perf 396 passenger up to '69, and even the low-perf '69 427 (from my P&A catalog July '69 Rev.).
                            I'm sure that if there were reliability problems, this spring would have been replaced during that timeframe. I do see that it's gone from my Jan '70 P&A catalogs, though, replaced by the 3859911.
                            y
                            • Dick W.
                              • 10483
                              #29
                              There were some awful slow learners at GM during that time period. If they had inventory in the warehouse, it most likely would have been used up before they replaced it. Plus the communication pipeline between dealers, factory service rep's, engineers, etc is not what it is today
                              Dick Whittington
                              • Don L.
                                • August 31, 2005
                                • 1006
                                #30
                                You might also consider looking at http://racingsprings.com/Multimedia/...talog_2012.pdf or on catalog www.racingsprings.com
                                They offer several springs that could be possibly retro fit to the engine. While they don't offer application information I know the PAC-1212X spring will retrofit into the LT engine group. For further information you can contact Matt Milkovich as I have worked with him in the past on similar retrofit discussions.
                                Don Lowe
                                NCRS #44382
                                Carolinas Chapter
