strut rod bracket question - NCRS Discussion Boards
  • Norris W.
    • December 1, 1982
    • 685
    I thought the strut rod bracket was the same for the '63 to '79 rears except for the sheet metal pieces welded under the '63 style for unknown reasons. I need a replacement for a friend's 67 who is removing the adjustable strut rods and the aftermarket bracket that came with it. I see on E bay that a lot of 'em are listed as '68 to '79. So what's the diff?
    • 15706
    Re: strut rod bracket question
    The geometry changed to lower the rear roll center a couple of inches. The '68-up bracket also required more "crush" on the exhaust pipes where they pass under the bracket.
      • 43289
      Norris------
      You need a GM #3817827 bracket. This bracket is applicable to 1963-67. It was discontinued without supercession in 1984 and I do not think it's reproduced. So, you'll have to look for a used example.
      1968-74 used bracket GM #3931805 and 1975-79 used bracket GM #356932. The latter will also SERVICE 1968-74 as the only difference is that it has an extra tab with hole for the 75+ catalytic converter shield. Both of these are discontinued, too. The 68-79 brackets are not correct for any 1963-67.
      • Paul D.
        • January 1, 1988
        • 101
        I have a couple of brackets at home.Can someone post a photo of the 2 styles to show the changes?.....Is the pt# stamped anywhere on the bracket?......P..
          • 43289
          Paul------
          Here they are:
            • 43289
            All------
            By the way, the attached photo shows the difference between the GM #3931805 (68-74) and the GM #356932 (75-79). The 3931805 does not have this "tab" and the 356932 (pictured) does. Otherwise, they are identical.
            • Wayne M.
              • March 1, 1980
              • 6414
              [QUOTE=Norris Wallace (6139);607245] I thought the strut rod bracket was the same for the '63 to '79 rears except for the sheet metal pieces welded under the '63 style for unknown reasons. ...../QUOTE]
              Just to refresh the memory for those watching, picture of sheet metal welded onto '63 up to mid-64 (?) can be seen in this link (also found in "similar links" feature, below). I thought they were for heat shielding from the exhaust pipe.
              https://www.forums.ncrs.org/showthread.php?43517-63-mid-64-(-)-strut-rod-bracket-heat-shields
