Ignition key warning switch - NCRS Discussion Boards
  • Terry B.
    • April 1, 2003
    • 50
    I have renewed the ignition key warning switch located inside the steering column twice over the last couple of years and the problem keeps coming back, i.e. when I remove the key and open the drivers door, the buzzer does not shut off. (If I play with the ignition key housing, it will stop...sometimes!). I suspect that I need a new ignition key warning switch. Does anyone know of a source for these switches?
    Web Master Miami Valley Chapter 2010 to present
    Newsletter Chairman Miami Valley Chapter 2003 to 2011
    Events Chairman Miami Valley Chapter 2010
    Miami Valley Chapter Secretary 2012 to 2015
    Miami Valley Chapter Media Chairman 2016
    Miami Valley Chapter Judging Chairman 2017 to present
  • Pat M.
    • April 1, 2006
    • 1582
    Re: Ignition key warning switch
    Terry, as of a couple years ago Dr. Rebuild had NOS C3 tele/tilt and standard column switches. I'm not sure they still have 'em but give them a try. Sounds like your plastic housing is cracked, which is pretty common with age.
    • Scott O.
      • December 9, 2009
      • 100
      Check Corvette Central I believe they carry the repro Lectric Limted one. It fit and works fine in my 78
      Scott
      • Terry B.
        • April 1, 2003
        • 50
        Thanks Pat, I'll give them a call
        • Jim S.
          • August 31, 2001
          • 730
          If you have replaced the key buzzer switch and the problem persists, than I would take a look at the ignition lock cylinder. The small plastic key buzzer tab on the cylinder may be sticking.
