Help w/'68 ignition switch remomal - NCRS Discussion Boards
  • George W.
    • May 31, 2000
    • 544
    Is there any way to remove the ignition switch assembly from the lower dash if key is lost?
    G
  • George W.
    • May 31, 2000
    • 544
    Re: Help w/'68 ignition switch remomal
    Any ideas?
      • 6948
      G
      George, I am not aware of any way to remove the cylinder without the Key, But my advice is to stop by a locksmith shop if you have one locally and ask him his advice, I have seen them work wonders with lost keys.maybe bring the lock cylinder with you.
      • Dick W.
        • 10483
        If the locks are original, you can get the code from the door lock cylinder
        Dick Whittington
        • Gary B.
          • February 1, 1997
          • 7045
          George,
          Some locksmiths have special sets of GM keys called "tryout" keys that have non-typical key cut depths (half-way between regular cuts). There are usually 64 keys per set of tryout keys and those 64 keys are supposed to open more than 75% of the locks for a given year. Tryout keys sets cost several hundred dollars per set and there are 8 tryout keys sets for the letter key years. So you need to find someone with a tryout key set for the C letter keys.
          Gary
          • Gary B.
            • February 1, 1997
            • 7045
            Dick,
            At some point during the C3 years I believe the key codes were no longer stamped into the door lock cylinders.
            Gary
            • George W.
              • May 31, 2000
              • 544
              Thanks for the ideas guys,
              Found a local locksmith---$20.00 to remove the cylinder and make a new key.
              G.
              • Gary B.
                • February 1, 1997
                • 7045
                G.
                George,
                I'm dying to know. How did the locksmith remove it?
                Also, the price of $20 is amazing. No way any locksmith in my area of Silicon Valley would come close to that price.
                Gary
