I have been researching the correct location to place new seat belt labels. In my search on corvette forum and images on the internet I am a little confused.
I'll try to explain. 1. On the driver side retractor I found an image that shows the label facing the seat at the end of the retracted belt. In other word, only visible when you extend the belt fully and it show the label upside down. The "GM" at the bottom. (See image). However, when I look at my seat belt I can see a clearly faded portion on the belt that faces the outside. 2. The buckle portion appears to be located facing the seat about 3" up from the end with "GM" at the top. (See second image) Can anyone help me clarify this?
If I go to the extent of adding the labels I would like to make sure I stitch them in the right place.
If I go to the extent of adding the labels I would like to make sure I stitch them in the right place.Thanks
