63 shifter problem on Munci 4 speed - NCRS Discussion Boards
+ More Options
Posts
  • Michael G.
    • November 12, 2008
    • 2157
    The shifter on my April-built 63 has apparently broken the pin that fixes the shift handle to the pivot. Is this something that can be replaced with the shifter in the car? If not, do I have to remove the trans to get the shifter out?
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • 6943
    Re: 63 shifter problem on Munci 4 speed
    Mike, The shifter can be removed while trans is in car. not sure about the pin, But its not likely as there really is not much access room with boot and plate out of the way. You can always give it a try
    • Jim T.
      • March 1, 1993
      • 5351
      Michael do you know if your shifter uses the same pin that was used in a 1963 Chevy Impala SS with factory 4-speed?
      • Michael G.
        • November 12, 2008
        • 2157
        Thanks, Ed, I'll try to remove the whole thing.
        Jim, sorry, I'm not familiar with the details of the Impala 4 Speed, although I once owned a 409
        Mike
