ci trunk lip - NCRS Discussion Boards
ci trunk lip
  • Jerry B.
    • August 31, 1994
    • 416
    ci trunk lip
    need detail photo showing detail of lip. currently at restoration shop
  • Garry B.
    • January 1, 1991
    • 660
    Re: ci trunk lip
    Jerry, by lip, do you mean the ridge over the trunk lock? I assume that your restoration shop is trying to recreate the original look. We need more information please.
    Garry #18531
    Garry Barnes #18531
    '67 Lynndale Blue Coupe- National TF, BG
    ​'67 Sunfire Yellow Coupe- 4 Star Bowtie,
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: ci trunk lip
      Jerry,
      If you are referring to the ridge above the trunk lock, you will find that the size of it can vary from a small ridge to one that is very well defined.
      When I did my 57 I took a dozen pictures of different cars and then formed the ridge. According to some people it is to large and to some it is not defined well enough (to small).
      Do some homework before you have the body shop do the work on it.
      My car is for driving so it will never be judged by anyone but me.
      Good luck.
      • Doug F.
        • November 1, 1983
        • 322
        Re: ci trunk lip
        here is a nice unmessed with 60, if that is what you are looking for
        • Bruce B.
          • May 31, 1996
          • 2930
          Re: ci trunk lip
          Doug,
          What is the original color of the car?
          Thanks.
          • Doug F.
            • November 1, 1983
            • 322
            Re: ci trunk lip
            Honduras Maroon and oxidization
            • Jerry B.
              • August 31, 1994
              • 416
              Re: ci trunk lip
              Doug,
              Thanks.
              cascade green Original
              • Adam S.
                • July 30, 2008
                • 167
                Re: ci trunk lip
                1957 AJs trunk lip on my car finished.jpg1957 AJs trunk lip on my car finished 2.jpgHere is picture of a good example of trunk lock lip if thats what you need
                • Pat M.
                  • April 1, 2006
                  • 1579
                  Re: ci trunk lip
                  I've seen this issue posted several times and find it interesting. I know nothing about C1s so I'm curious - if you sand the ridge completely off wouldn't there be a hole there? Or was it there and people just glassed it over?
                  • Jerry B.
                    • August 31, 1994
                    • 416
                    Re: ci trunk lip
                    Adam, that photo should be part of a supplement fot the 57 judging nanual. Perfect
                    • Adam S.
                      • July 30, 2008
                      • 167
                      Re: ci trunk lip
                      Thanks Jerry, I was very lucky my trunk lid was all original with original paint wore off........
                      • Adam S.
                        • July 30, 2008
                        • 167
                        Re: ci trunk lip
                        Pat, that area is solid & thick as it was molded that way, a lot of the trunk lids were sanded smooth on the first repaints and with little effert if you did not pay attention when you are sanding with a air sander the ridge disappears like it was never there, just a little ring of gell coat missing...........
                        • Pat M.
                          • April 1, 2006
                          • 1579
                          Re: ci trunk lip
                          Gotcha, interesting, thanks.
