69 Alternator Photo - NCRS Discussion Boards
69 Alternator Photo
  • Dennis W.
    • July 27, 2011
    • 63
    69 Alternator Photo
    Does anyone have a photo of the backside of a correctly installed 1100825 61A alternator? My alternator just returned from John Pirkle (outstanding result) and I am about to reinstall it. The rear half of the alternator case was turned 90 degrees when I removed it so I have no reference for how the alternator cable & wire support should be correctly bolted to the alternator. Thanks.
    Dennis Wright
    '69 White/Red Coupe
    L46/M20/PS/PB/AC
    404/388-7686 (c)
  • John C.
    • January 1, 2005
    • 616
    Re: 69 Alternator Photo
    Dennis
    Below is a picture of a non-power steering car.
    John
    • Dennis W.
      • July 27, 2011
      • 63
      John - Many thanks, this is exactly what I need. No need to remove yours but do you happen to know how long the bolt is that secures the wiring harness bracket? Mine is about an inch long and I am concerned that it is longer than it should be. I had a temporary unit installed while mine was being restored. I am concerned that the bolt they removed may not be the one they used to install the temporary unit. It didn't matter on the temporary unit because it was a newer '72 or so that had raised boss so the longer bolt would not have mattered.
      Whether you know or not, thanks again for sending the photo. Dennis Wright
      Dennis Wright
      '69 White/Red Coupe
      L46/M20/PS/PB/AC
      404/388-7686 (c)
      • John C.
        • January 1, 2005
        • 616
        Dennis
        I don't remember what the bolt length is, but 1 inch seems to long to me. I can't check my car right now as it is currently stored away from home.
        John
        • Floyd B.
          • November 1, 2002
          • 1046
          I believe power steering vs. no power steering makes a difference because BB engines w/ PS had the alternator installed up-side-down.
          "Drive it like you stole it"
          • Dennis W.
            • July 27, 2011
            • 63
            Thanks again, John. The photo was very helpful and i will get a shorter bolt to be on the safe side.
            DRW
            Dennis Wright
            '69 White/Red Coupe
            L46/M20/PS/PB/AC
            404/388-7686 (c)
