67 ammeter - NCRS Discussion Boards
67 ammeter
  • Ralph P.
    • February 1, 1990
    • 253
    67 ammeter
    A couple of questions for checking this gauge connection with the dash removed.....
    1. What voltage should show on the 2 connector wires ( battery connected.. gauge not connected) ?
    2. Should the harness be grounded for this test?
    ......just trying to isolate my problem to wiring or gauge
    Thanks!
    Re: 67 ammeter
    Thanks!
    Ralph -
    A VOM should show battery voltage on both terminals in the battery gauge connector; the black wire goes to the big battery cable stud on the starter solenoid, and the black/white wire goes to the screw terminal buss on the horn relay - both are hot all the time, key on or off. Both wires go through the multiple connectors on the engine side of the fuse block, and corrosion or terminal push-out in those connectors is not unusual.
    • Ralph P.
      • February 1, 1990
      • 253
      Re: 67 ammeter
      Thanks, John!
