1970 small block cooling fan removal - NCRS Discussion Boards
  • Bill B.
    • September 19, 2011
    • 44
    What is the proper way to remove a cooling fan from a 1970 small block (300 HP)?
    • 15599
    Re: 1970 small block cooling fan removal
    You will have to remove the fan and clutch as an assembly = remove 4 nuts (or four bolts) at the water pump flange. Once you have the assembly out the fan can be separated from the clutch = remove another four nuts. You will likely have to relieve the belt tension from the accessory drive(s) before the first step.
    • Bill B.
      • 44
      Thanks Terry, i can always count on you for an accurate quick response. That is sort of what i thought, I just wanted to confirm the correct process. Hope all is well...
      Bill
      • Gerard R.
        • November 1, 1993
        • 61
        Bill did you ever receive the info on my 70 454.... jerry
