1967 horns - NCRS Discussion Boards
1967 horns
  • Michael P.
    • March 2, 2009
    • 23
    1967 horns
    Were the 1967 corvette horns date coded?
  • Scott S.
    • September 11, 2009
    • 1961
    Re: 1967 horns
    Michael,
    Yes, the horns are date coded, it's not always easy to read the numbers and letters clearly. The horns (including date code info) are described on p. 132 of the 1967 Judging Guide.
    • Dennis O.
      • December 1, 1988
      • 438
      Re: 1967 horns
      As said above, they can sometimes be hard to read. On mine, when I took the first one off, I couldn't decipher the date. When I removed the second one, it became obvious how it was done, and I could read the date on the first.
      • Michael P.
        • March 2, 2009
        • 23
        Re: 1967 horns
        Thanks guys, i guess my next question is: does anyone have date coded horns for March 30, 1967 production.
        • Steve B.
          • March 1, 2002
          • 1195
          Re: 1967 horns
          I would contact Joe Perri. Do a search as it should have his number, great guy!
          • Wayne M.
            • March 1, 1980
            • 6414
            Re: 1967 horns
            Here's a pair off an early '65; horns butted together. Believe #'s are same for '67 (ie. 487, 488). These are dated 4G3, 4H4. [year month week].
            • Ara G.
              • January 31, 2008
              • 1108
              Re: 1967 horns
              Mike
              If he doesn't have dated ones for you car I have a pair of original horns dated nicely for your car - 7A2 and 7B1
              • Joseph M.
                • June 30, 1999
                • 334
                Re: 1967 horns
                What were the typical headmarks for the bolts that attach the horns on a 67. Also usual finish and type of washer used. Tx.
                  Re: 1967 horns
                  Joe -
                  It's the same bolt used to attach the upper end of the starter brace to the block - zinc-plated 5/16"-18 x 5/8" with a captured external-tooth star washer.
                  • Chuck M.
                    • February 1, 2002
                    • 335
                    Re: 1967 horns
                    Give Dennis Portka a call. I don't have his number handy but he advertises in the driveline and hemmings.
                    Chuck
