"68" 327-350 shp metal shim gasket under the carb. - NCRS Discussion Boards
  • Jeff P.
    • October 21, 2011
    • 287
    Does this engine use the metal shim gasket under the carb ? If so do i use any other gaskets with this shim gasket ? This is the stock 803 intake manifold with the stock 219 carb. Any idea's why chevy used this shim? Thanks in advance.
    • 43259
    Re: "68" 327-350 shp metal shim gasket under the carb.
    Jeff------
    Yes, the stainless steel BAFFLE is used in conjunction with a composition-type gasket with steel core. The gasket goes on the manifold first, then the baffle, and then the carburetor.
    The baffle separates and protects the carburetor from the hot exhaust gas which passes through the heat slot at the front of the manifold flange. Your best bet is to disable this heat slot by plugging the holes on either end of it. Then, the baffle is not so important, but I'd still use it.
    • Joseph K.
      • August 26, 2008
      • 407
      Jeff,
      Joe L's idea works well. Stops the gas from boiling in the carb. I used 2 small freeze out plugs and they fit snugly in the 2 holes.
      Joe K
      • Jim T.
        • March 1, 1993
        • 5351
        I have a 68 327/350 with the original metal stainless steel baffle. I also plugged the heat slot.
        • Jeff P.
          • October 21, 2011
          • 287
          I also see this Baffle and Gasket on E-Bay with-out the Heat slot in both pieces. I could use these parts also ??
            • 43259
            Jeff-----
            There should be no slot in the steel baffle, even for 68-69. The slot is in the manifold flange as well as the gasket. I don't think any baffle was used after 1969 since Chevrolet wisely abandoned the use of the heat slot carburetor heat system although some applications did use a combined gasket and heat shield that extended beyond the carburetor flange. I don't know that the later gaskets will work properly for 1968-69. They might but I would not count on it. I certainly would not use them to block the heat slot system. Use the plugs for that; the drive plugs are quite easy to install with the manifold on the engine. Then, just use the stock 68-69 baffle and gasket.
            • Jeff P.
              • October 21, 2011
              • 287
              Thanks for the clarification on the use of this stainless baffle, and modifications to the manifold.
