NOS GM 454 pistons LS-5 - NCRS Discussion Boards
  • Lyndon S.
    • April 30, 1988
    • 1027
    Are 454 LS-5 pistons still available from GM any more? What if any parts are still available for LS-5 engines any more from GM
    • 43279
    Re: NOS GM 454 pistons LS-5
    Lyndon-----
    LS-5 pistons have been discontinued by GM for over 30 years.
    So, what's still available? Very little. Things like head bolts, engine bearings, flywheel, timing set parts, and a few other odds-and-ends are about it.
    • Lyndon S.
      • April 30, 1988
      • 1027
      Thanks Joe
      Would that chain be better than a after market chain? Could you post what the number is for the flywheel.
      And can one still get a balancer for the LS-5 from GM any more
        • 43279
        Thanks Joe
        Lyndon-----
        The GM timing set uses a nylon/aluminum cam sprocket and Morse-type chain. I use and recommend only Cloyes True Roller sets. The flywheel is GM #3993827. A balancer is also still available but not under the original part number. However, this balancer is very similar to the original except that it is powder-coated black. It is GM #10216339.
