Where does this spring go? - NCRS Discussion Boards
+ More Options
Posts
  • John F.
    • March 23, 2008
    • 2415
    While working under the car today I found this little spring with one end broken off. What you see is about 3" long. It was hanging from the clutch linkage. What is it and where does it go? Can you buy them?
  • Joe R.
    • July 31, 1976
    • 4551
    Re: Where does this spring go?
    Believe it to be the anti rattle spring for the shifter handle! Attaches to one side of the shifter handle to keep a little tension on the shifter handle and keep it from rattling.
    JR
    • Mike E.
      • February 28, 1975
      • 5141
      There should be two identical--one on each end of the clutch rod from bell crank to fork.
      • Joe R.
        • July 31, 1976
        • 4551
        Rev Mike,
        That would be correct if we were talking C-2's. Think he has a 62 C-1. If he has a couple of springs he's got the wrong push rod. 62's had a threaded rod on one end and a lock nut with a spring on the other for the clutch fork.
        Your probably correct that it is the spring for the push rod being that it was hanging on the push rod in the first place. There is a slot on the clutch fork for one end of the spring and a small notch on the push rod for the other.
        JR
        • John F.
          • March 23, 2008
          • 2415
          I think I found it in the AIM Section 6, Sheet 6. Part number 3713738. CC has them for $2.95. Appears to attach to the clutch fork and then to the rod. Is that right? This is an early 62 vette.
          • Michael H.
            • January 29, 2008
            • 7477
            Originally posted by Joe Ray (1011)
            Rev Mike,
            JR
            JR,
            This is a new 3760384 spring for a 58-63 transmission control. It looks different than John's spring.
            • Terry D.
              • May 31, 1987
              • 2696
              John
              Yes that is correct
              • Bill M.
                • April 1, 1977
                • 1386
                Here's a pic:
                • Joe R.
                  • July 31, 1976
                  • 4551
                  Originally posted by Bill Mashinter (1350)
                  Here's a pic:
                  Right Spring! Wrong Clevis Pin!
                  JR
                  • Peter M.
                    • April 8, 2007
                    • 570
                    Looks like a broken clutch return spring to me.
                    • John F.
                      • March 23, 2008
                      • 2415
                      Thank you all that replied. I will be ordering one from CC.
                      • Mike E.
                        • February 28, 1975
                        • 5141
                        Return spring, no, anti-rattle spring, yes. Return spring on a 62 is a "Godzilla" spring.
                        • John F.
                          • March 23, 2008
                          • 2415
                          Mike, I ordered the one shown in the above pic.
