1972 A/C Drier - NCRS Discussion Boards
1972 A/C Drier
    • 43289
    Re: 1972 A/C Drier
    Dom
    The VIR (Valve In Receiver) system in your 1974 does have a rebuildable receiver/dryer. Corvette got this system in 1973 or 1974.
    Terry-------
    1973. GM #6598830.
    • Domenic T.
      • January 29, 2010
      • 2452
      Re: 1972 A/C Drier
      Terry,
      My A/C was working good but the hoses looked bad so I decided to rebuild the whole system when I rebuilt the car. When I took the receiver/drier apart I found it about half full of desert sand. The desiccant bag was not ripped and it was full. The fine screen in the receiver/drier stopped the sand from going any farther. The only thing I can think of is that the car was parked outside for a few years near my hangar where sand would blow over the ramp. This was years ago and as I remember, either the compressor was removed or a hose but all was plugged. I installed the compressor and charged the system and drove the car a few years before I discovered the sand.
      When I rebuilt the system and found the sand, the compressor had no indication that sand went thru it as the pistons, cylinders, and rings had no damage. I think human factor was involved as there were things stollen off the car.
      The amazing thing is that all worked. Makes one think, when buying a new or rebuilt compressor, they always insist that you replace the receiver/ drier!
      Dom
        • 43289
        #18
        Re: 1972 A/C Drier
        By the way, you don't want to need one of these 73-76 receiver/dryer assemblies. The only source I know of is USED. You can obtain the dessicant kit through Delco or other aftermarket but, as far as I know, the complete assemblies are not available.
        • Domenic T.
          • January 29, 2010
          • 2452
          #19
          Re: 1972 A/C Drier
          Joe,
          Makes one want to visit Pick A Part or another self serve wrecking yard. As for the deseccant, I rejuvinate it in my storage plugs by putting it in the oven till it gets the correct color, but the one in the receiver/dryer instantly gets oil soaked and my guess is that it is useless at that point.
          Dom
