1972 A/C Drier - NCRS Discussion Boards
1972 A/C Drier
  • Christopher K.
    • September 10, 2007
    • 311
    1972 A/C Drier
    I removed my receiver-drier from my '72. I've searched the archives quite a bit so I'm pretty sure it's not an original drier, just wanted to make sure.
    Also, does the current Delco replacement have the same appearance as the original?
    Thanks for the help
    Chris
    '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
    '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
    • 43287
    Re: 1972 A/C Drier
    Thanks for the help
    Chris-----
    The one pictured is not an original piece or, even, a GM or Delco replacement.
    The current GM and Delco piece is GM #3046236. It has been the replacement part number for more than 25 years. It is not configured exactly like the original but is as close as you're going to get unless you can find an NOS GM #3012944.
    • Christopher K.
      • 311
      Re: 1972 A/C Drier
      Thanks Joe, for the quick reply.I'm not sure I could spot an NOS one, does anyone have a picture?(Yes, I have read the tech manual description)
      Chris
      • Ed D.
        • December 1, 1990
        • 330
        Re: 1972 A/C Drier
        Chris,
        Here are photos of an original drier that was removed from my 72
        Ed
        Ed DiNapoli
        CNJ Chapter Past Chairman/Co Founder
        1972 Targa Blue Coupe, Original Owner,
        Duntov Award, Sam Foltz Award,
        Founders Award, NCRS Gallery VIII
        2011 Corvette Convertible
        NCRS Presidents Award 2014
        • Christopher K.
          • 311
          Re: 1972 A/C Drier
          Thanks Ed,
          That's exactly what I was looking for! I've seen lots of C2 drier pics, but that's the first actual C3 picture I've seen.
          It looks a lot like the current Delco replacement, 3046236. Did you rebuild your old one, or purchase a new one?
          Chris
          • Ed D.
            • December 1, 1990
            • 330
            Re: 1972 A/C Drier
            Chris,
            I replaced it. I just had the car judged in Novi and did not lose any points for the replacement.
            Ed
            Ed DiNapoli
            • Christopher K.
              • 311
              Re: 1972 A/C Drier
              Great info, thanks.
              Off topic, but....
              Do you have your a/c original hoses, or did you rebuild/replace? Mine are original, but I have rubber wearing off on one spot down to the first cord on the low pressure return. Still trying to figure out what to do, repros are not the same at all.
              Chris
              • Ed D.
                • December 1, 1990
                • 330
                Re: 1972 A/C Drier
                All are original, except for the hose coming off the compressor manifold near the exhaust.
                Ed DiNapoli
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  Re: 1972 A/C Drier
                  Chris-----
                  There's an NOS 3012944 on eBay right now (link)
                  There's also a new 3046236 so you can compare (link)
                  • Christopher K.
                    • 311
                    Re: 1972 A/C Drier
                    Thanks Wayne,
                    That's really helpful, a great way to compare them.
                    Chris
                    • Phil D.
                      • January 17, 2008
                      • 206
                      Re: 1972 A/C Drier
                      I have here a drier removed from a 72 (complete with overspray from a repaint) that appears much like Ed's but with some differences. The letters EVAP and COND appear to be stamped instead of raised. And the letters on the bottom are different (date/mfg codes perhaps?). Debating if this is an original and should be taken to be rebuilt or should I toss it and buy a replacement?
                      IMG_3567_zpszfatrpeh.jpgIMG_3566_zpsgfwfntix.jpgIMG_3565_zpsmcjvc52h.jpgIMG_3561_zpszsd7ck2q.jpg
                      • Domenic T.
                        • January 29, 2010
                        • 2452
                        Re: 1972 A/C Drier
                        The rebuild is only a O- ring and a new desiccant PAC.
                        Dom
                        • Phil D.
                          • January 17, 2008
                          • 206
                          Re: 1972 A/C Drier
                          There is a company here in Fort Worth that will cut it open, replace the desiccant pack and weld it back together for me. Question is whether or not this unit is a 1972 original. If not original, then it would be a waste of money to do that.
                          • Domenic T.
                            • January 29, 2010
                            • 2452
                            Re: 1972 A/C Drier
                            Dom
                            Sorry,
                            My post was wrong, I should have looked at the pics closer! I have a 74 Laguna S3 and it is rebuildable. It can be taken apart on the work bench and re done.
                            Dom
                              • 15638
                              Re: 1972 A/C Drier
                              Dom
                              The VIR (Valve In Receiver) system in your 1974 does have a rebuildable receiver/dryer. Corvette got this system in 1973 or 1974.
