Big block threaded plugs - NCRS Discussion Boards
+ More Options
Posts
  • Keith L.
    • April 7, 2008
    • 378
    What type plug sealed the hole under the fuel pump on a 69 big block? And were the oil galley plugs internal square or allen head?
    • 43246
    Re: Big block threaded plugs
    Keith-----
    Plug below fuel pump was 3/8" NPT, dryseal, and with SQUARE EXTERNAL HEAD.
    Oil gallery plugs were SQUARE INTERNAL HEAD.
    • Keith L.
      • April 7, 2008
      • 378
      Thanks Joe. What can you tell me about under the rear main cap?
        • 43246
        Keith-----
        Do you mean the plugs?
        • Keith L.
          • April 7, 2008
          • 378
          Yes Joe. I think there is one under the cap kinda like a small freeze plug. When I got my block back I assumed he put all the old stuff in the box that had studds and guidplates from my heads but they are long gone now.
          • Keith L.
            • April 7, 2008
            • 378
            Maybe the ones under the rear main are small block only???
              • 43246
              Keith-----
              I don't recall any being under the rear cap on a big block.
              • Clem Z.
                • January 1, 2006
                • 9427
                the only internal plug used in the oil system of a BBC is if you use a external oil cooler to direct the oil flow thru the cooler
                • Keith L.
                  • April 7, 2008
                  • 378
                  Thanks guys. After looking at the cap I guess I must have read a small block thread.
