65 Differential Tag - NCRS Discussion Boards
65 Differential Tag
  • Don H.
    • December 1, 1981
    • 1501
    65 Differential Tag
    Please give opinions on which of these differential tags you consider to be correct for a 1965 with posi. The JG says the red plastic is correct but I found the metal on my fairly original car. Thanks, Don H.
  • Jim D.
    • 2885
    Re: 65 Differential Tag
    My 65 has the original red plastic tag pictured above and my 60 has the metal tag.
    • Timothy B.
      • April 30, 1983
      • 5203
      I have access to a November built 65 that's very original and from memory it's the metal tag on the early 65's. I will double check later today and let you know as this part may have changed during the 65 production.
      • Gary R.
        • April 1, 1989
        • 1808
        I agree with Tim, I think most of the 65's I've built had the plastic tag, the wording changed on them over the years too. Some 65's also came with the much weaker R&P carried over from the 63-64 run.
        • Ray K.
          • July 31, 1985
          • 376
          My June of '65 Corvette has the red plastic tag. I believe the metal tags were on 1963-64 vehicles but could have been carried over to early '65 production.
          • James B.
            • July 30, 2008
            • 38
            My early February 65 coupe has the round metal tag. The differential is original to this low mileage car.
            • Chuck B.
              • August 31, 1987
              • 122
              My 60K mile Dec. 2nd built car has the red plastic tag.
              Chuck Banks
              • Mark S.
                • April 1, 2002
                • 40
                My Sep built 65 has the metal tag. The differential date is 2 Sep 64.
                • Don H.
                  • December 1, 1981
                  • 1501
                  It sounds like it was a mix. My car was built May 12, 1965 and as I said before, the car is fairly original. I could see someone removing the tag but found it unusual they would replace it (if the original was plastic) with a metal tag. Thanks for the replies, Don H.
