C2 Electrical questions - NCRS Discussion Boards
  • Doug L.
    • March 14, 2010
    • 442
    Hello all,
    My restored voltage regulator and horn relay arrived today. Thanks John Pirkle Jr. 1964 L-84.
    I understand that I do not need to polarize the system because it has an alternator. Can someone confirm?
    I also have some doubts about the connection of the horn relay. The plastic connector is straight forward, however I have 2 bundles of wires to connect. One has 2 red wires. The other has 2 reds and 1 black/white. The AIM labels one set as "red" and doesn't label the other set. Since both have red conductors it is a little ambiguous. The electrical schematic in the shop manual showns both bundles clearly but doesn't ID either of the 2 terminals on the relay. The relay itself has 1 post marker "Bat" but the other post has no marks.
    Any help will be greatly appreciated.
    Thanks-Doug
    Re: C2 Electrical questions
    Originally posted by Doug Loeffler (51544)
    Hello all,
    Thanks-Doug
    Doug -
    There's no need to polarize with an alternator - that only applies with generators.
    Both screws on the buss are electrically common - either screw is 12 volts, hot all the time; doesn't matter which screw you use for those connections. The reds are hot power feeds and the black/white is the sense wire for the battery gauge.
    • Doug L.
      • March 14, 2010
      • 442
      Thanks John. I don't know what I'd do without all the help you guys provide.
      Doug
