1960 Window regulator removal. - NCRS Discussion Boards
  • Lou S.
    • September 5, 2011
    • 4
    I need step by step instruction on how to remove a driver side window regualtor from a 1960 vette.
  • Steven B.
    • June 30, 1982
    • 4012
    Re: 1960 Window regulator removal.
    Lou, I can't get to my ST-12 (available from the NCRS store if you don't have one) now but the steps are in the Body Section. As I recall when I did my '57 you first have to remove regulator crank, door panel, the access panels, window glass, and the screws holding the regulators to the door and pull them out. It isn't very hard.
    Steve
    • Joe M.
      • April 30, 1990
      • 1342
      ST-12 Body Section pages 17-18.
      • Philip P.
        • February 28, 2011
        • 558
        While the ST-12 is helpful I still was not able to get my regulator out and gave up for a later day but I did get the following advice:
        Operate the regulator until it is straight. That is, the main arm extends out straight from the body of the gear case part of the device. In this configuration, you should be able to twist it past the center bracing and then bring it out through the large access hole. If you still have trouble, move the arm slightly away from straight and try again. You will get it out.
        Hope this helps
        Phil
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11364
          Also, Remember to be extremely careful when it's loose in there.......
          There is a very strong spring and if the gears break loose the regulator becomes a pair of scissors!!
          • Lou S.
            • September 5, 2011
            • 4
            What is ST-12?
            • Philip P.
              • February 28, 2011
              • 558
              It is the Corvette Servicing Guide for 1953 to 1962. It is a must if you are working on your car it is available from most of the Corvette parts houses.
              Phil
              • Philip P.
                • February 28, 2011
                • 558
                Attached is the section from the ST-12 for the manual regulator.
                Phil
                • Terry D.
                  • May 31, 1987
                  • 2697
                  Lou
                  You can also buy the ST-12 right here at the NCRS store. Why not support this instead of some other vendor? As said before, if you are going to work on your C1 Corvette it is a must to have.
                  • Lou S.
                    • September 5, 2011
                    • 4
                    Can you send me the door window glass removal form this section. thanks for your help.
                    • Philip P.
                      • February 28, 2011
                      • 558
                      Here it is the site would not allow it as one file hope this works.
                      Did not mean to miss the ST-12 available at NCRS.
                      Phil
                      • Lou S.
                        • September 5, 2011
                        • 4
                        Thanks, I did buy a copy from NCRS today.
