Block casting date vs car build date - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    I remember reading the engine date is usually within 2 weeks of the cars build date but I can't remember if they were talking about the engines ASSEMBLY date on the front pad or the casting date on the rear of the block.
    so what is typical for the cars build date (birthday) vs engine casting date (rear of block) and assembly date (front pad)?
    thanks
    Re: Block casting date vs car build date
    Brandon -
    What's the engine assembly date (on the front block pad)?
    • Ray K.
      • July 31, 1985
      • 374
      Brandon
      My 1965 generally falls within the two week window --- mid May engine assembly from pad data and June 1st production date for car.
      Ray
      • Brandon T.
        • October 23, 2008
        • 872
        thanks for the info, what about the casting date on the rear of the block?
        • Harry S.
          • July 31, 2002
          • 5315
          For my 63 - Block Cast 4/5, engine assembly 4/15, car build date 4/20.
          • William D.
            • April 1, 1993
            • 101
            My 65 396 coupe - block casting date-june 9, motor assembly june 22, car build date july 1st
            1965 Conv 327/365HP 4 sp, 3.73, KO's, pb 96.6 pts
            1965 Coupe fuelie, F40, 411's, teak/tele, 32K, 98 pts
            • Richard E.
              • April 30, 1992
              • 190
              My 67/427/435 cast date is Jan 26th , build date feb 23rd and car build March 2nd
              • Harry S.
                • July 31, 2002
                • 5315
                If you analyze the data..... When an engine is a higher price option such as fuel injection or a 427 the greater the time between casting to engine build and car build date. When the engine is a standard engine the lesser the time between casting and car build date. They had to have the engines available even if they sat waiting for an order.
                • Brandon T.
                  • October 23, 2008
                  • 872
                  Thanks guys, my casting date is June 4th 58 and the cars build date is july 15th 58. I guess it was the assembly date they said was usually 2 weeks because casting vs build date looks to be around a month from what I see, mine included.
                  • Brandon T.
                    • October 23, 2008
                    • 872
                    Good info here for baseline on dates, anymore? any c1's info by chance?
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11325
                      A friend's 1957:
                      E57S1044xx - Build Apx June 6th, 1957
                      Engine Casting# - 3731548
                      Engine Cast Date - D197 April 19, 1957
                      Assy Stamp Pad - F522FH Flint May 22, 1957
                      Summary: Engine Cast April 19, Car built June 6 (~48 days)
                      My previous 1962:
                      VIN# 20867S100483 - Build Apx Sep 15, 1961
                      Engine Casting# 3782870
                      Engine Cast Date H251 Aug 25, 1961
                      Assy Stamp 2100483 F0828RC Flint Aug 28, 1961
                      Summary: Engine Cast Aug 25, Car built Sep 15 (~21 days)
                      • Brandon T.
                        • October 23, 2008
                        • 872
                        Thanks for the info Richard!
