67 Crank handle dyeing - NCRS Discussion Boards
  • Al R.
    • June 30, 1988
    • 688
    Can the rubber portion of the crank handle be successfully redyed so it does not crack or popoff with use? Anyone done this before? I've been unsuccessful so far in locating a NOS set of white vent window cranks, so I was wondering........?
  • Gene M.
    • April 1, 1985
    • 4233
    Re: 67 Crank handle dyeing
    Al, repop vent window cranks are available with white knobs.
    • Larry M.
      • January 1, 1992
      • 2703
      Al:
      I have read where folks installed new/replacement vinyl knobs on their old handles. They immersed the handles in boiling water to soften the vinyl knob, then removed it. Did the same with the reproduction handles or the reproduction knobs. Then installed the correct color knobs while the vinyl was still hot.
      I have not personally tried this, but it should work. A lot of trouble when good quality reproductions are available (as Gene stated above). Check the archives for information. I will also look for the article.
      Larry
      EDIT: I did a quick search under "window crank handles". One of many threads: https://www.forums.ncrs.org/showthre...+crank+handles
      Larry
      • Al R.
        • June 30, 1988
        • 688
        Thanks Gene & Larry, I wasn't sure how close the repos were to original. My originals are dirty , unable to clean up & the chrome has the usual bubbles assoc with pot metal aging. I'll try a set from CC
