Water pump pulley for 1967 427/400 with c60 a/c power steering no Air (k19) - NCRS Discussion Boards
  • Kevin L.
    • April 1, 1985
    • 2
    Doe's any one know the correct # that should be stamped in the three groove water pump pulley for a 1967 427/400 with factory a/c and power steering no a.i.r. . I know it is suppose to be a one piece pulley. I have two but I think they are for a later year, possibly a 1968 or 1967 427 .
    the two part#'s I have are 3992071BE and 3889372BF. Actually they are the # stamped in the pulley's .
    Thank-you, Kevin L
    • 43258
    Re: Water pump pulley for 1967 427/400 with c60 a/c power steering no Air (k19)
    Thank-you, Kevin L
    Kevin------
    The 3889372 is the correct one for your application.
    • Kevin L.
      • April 1, 1985
      • 2
      Joe, thank-you for getting back to me. That is the one that I will install. I will advertise the other one in the Driveline.
      Is the stamped # 3889372BF the same as the part # that was used in the original part's book?
      Thanks again for you help. Kevin Lalor
        • 43258
        Kevin------
        Yes, the 3889372 was the original part number, both PRODUCTION and SERVICE. GM #3992071 is a pulley used for 1971-74 Corvette big block applications. It won't even work properly for your application unless you also use a 71-74 waterpump with 3/4" pilot shaft and a 71-74 fan clutch with 3/4" pilot hole.
