The revision record in the 1967 AIM (UPC U69-A2) says Item 17 tag WAS 3844066 tag, dated 1-19-67. The 1967 JG (page 35) says this GM 3844066 tag is the correct radio tag. The new tag, which was used through at least early 1969, was GM 3886966. But was the old tag (GM 3844066) used on ANY 1967 Corvettes?
The printed instructions on the earlier 3844066 tag read in part:
"Optimum Frequency Modulation
Reception Will Be Obtained
After Adjusting The Antenna
Mast To A Height Of 30 Inches"
Since all 1967 model year Corvettes had FIXED MAST antennas, the instructions on the earlier radio tag would not be relevant, but according to the AIM, it was used until at least 1-19-67. Should a January 11th car have the earlier tag, or did all Corvettes from the start of 1967 production use the later GM 3886966 tag used through 1969E?
