Rookie need some help! Dash cluster. - NCRS Discussion Boards
  • Al E.
    • September 5, 2011
    • 313
    I need to remove the ammeter, in my 1960..it is causing a short of some kind in the ignition switch. Can this be serviced while the cluster is in place? Or do i have to pull the steering column and dash pad and windshield just to get to it?
  • Dennis C.
    • June 30, 2002
    • 888
    Re: Rookie need some help! Dash cluster.
    Z
    Al,
    While it is not easy, yes, you can get it out. Disconnect the battery, label the wires, and then remove them. The outboard nut that holds the gauge in place may not be easy to get out, but it can be removed.
    You might want to take the seat out to make it a little bit easier to lay under the dash. I would also suggest taking several photos under the dash before you begin.
    Good luck.
    Dennis
    • Al E.
      • September 5, 2011
      • 313
      Sounds like a plan..thanks
      • Philip P.
        • February 28, 2011
        • 558
        Al, if you have not all ready order you need to get the ST-12 it has much of the information you need to work on C! corvettes that is not covered in
        passanger car manual. attached are two page from the ST-12 on the dash Hope this helps.
        Phil
        • Bill M.
          • April 1, 1977
          • 1386
          Please explain why you think the ammeter is causing a short in the ignition switch....?
          • Terry D.
            • May 31, 1987
            • 2697
            Agree with Bill, why do you think it is the gauge at fault? Most of the wiring up front runs thru the amp gauge. If it is something else you could be wasting your time.
            TERRY
            • Al E.
              • September 5, 2011
              • 313
              There is a nut that is rusty and will not tighten, and it shorts when it is wiggled and causes the ignition not to work. But when you make the adjustments it works fine. I think the little stud inside the gauge is loose and needs to be replaced or repaired.
              • Bill M.
                • April 1, 1977
                • 1386
                Agree. The ignition "shorting" is what we wondered about; just semantics. Good luck.
