Do 69 427/390 cars have a steel vacuum advance line? - NCRS Discussion Boards
  • Gary H.
    • June 8, 2008
    • 308
    I am using a rubber hose off the intake. I was told that it was not correct, but cant seem to find a steel line for 390 horse...only for 300,350,400 and 435.
    Gary
  • Paul O.
    • August 31, 1990
    • 1716
    Re: Do 69 427/390 cars have a steel vacuum advance line?
    Gary
    Go to Doc Rebuild site here is a link to the page. http://docrebuild.com/dr-r-web/VAC-ADVN.pdf Look at item "P" it list the for 300 350 390 HP 68-69 cars but the 390 is split up making it hard to see.
    Paul 18046
    • Gary H.
      • June 8, 2008
      • 308
      I have factory AC. AIM shows setup with AC showing three way T in manifold with hose running directly to vacuum advance. Calls it Prod spark hose.
      • Paul O.
        • August 31, 1990
        • 1716
        Here is a list of manifold vacuum fittings. http://docrebuild.com/dr-r-web/CARB-GSKT.pdf
        Paul 18046
        • Dale C.
          • November 1, 1999
          • 844
          Gary
          I think you will find that the steel tube/hose line running to base of carburetor for vacuum pick up was used on the 4 barrel carburetor without C60, see AIM 6-C1. The Air conditioned BB cars had a different vacuum pick up. The system had an intake off the intake manifold with splitter (see AIM C60-,C8) with the two different fittings shown, the one for power brake having the additional lead. I don't think they had the steel tube on the A/C BB's?? There is also some info (shownig the same plunbing) on this in the Feb 68 Chevy Service News letter for 427's with A/C on page 5. Is your car C60? I see that it is. Sorry this is on the 68. Don't know if the 69 is the same.
          Dale
