1970 POA cap - NCRS Discussion Boards
1970 POA cap
  • D S.
    • March 1, 2005
    • 1551
    1970 POA cap
    On my POA valve there is supposed to be a cap on a threaded stem. Is that cap the same as the ones on the compressor manifold?
    Scott Sims
    Texas Chapter
  • Bill C.
    • July 15, 2007
    • 904
    Re: 1970 POA cap
    Scott,
    from what I remember (80%) it is a aluminum cap, kind of thin walled. It is not the brass cap....
    • Peter L.
      • May 31, 1983
      • 1930
      Re: 1970 POA cap
      Scott - The cap that I have seen on the POA valve Schrader valve is different from the hex-shaped cap used on the Schrader valve on the on the A/C muffler assembly. The cap on the 67 POA Schrader valve is a brass barrel shaped cap with a flat top and grooves running top to bottom on the sides. I have also seen an identically configured aluminum barrel shaped cap on NOS Frigidaire POA valves. Pete
      • D S.
        • March 1, 2005
        • 1551
        Re: 1970 POA cap
        Pete, thanks for the information. Sorry I missed you at Frisco. I was there Friday and spoke to you about purchasing key blanks. When I returned Saturday after lunch you were gone. Great show.
        Scott
