looking to buy some to paint the bird cage but with no luck at all my local paint stores. they said they stop selling that 15 years ago due to regulations. John Z gave me a link to aircraftspruce.com. they do sell it only in spray cans. am I buying true zinc chromate primer? what is every body else using ?
Re: zinc chromate primer
Much of the time it's just flat sheen green paint in a can, and not really zinc chromate.
If it were me I'd probably use two stage primer and then cover it with a locally sourced flat sheen green tinted to match the original stuff.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Several marine supply houses actually offer true zinc chromate because outboard engines use it on the aluminum parts. I can't remember the common brand name for the generic, but the Mercury dealers have it under the factory Merc brand.- Top
Moller Zinc Chromate is available at most marine / aviation dealers, West Marine has it in stock. Color is not exact as original but close.
Patrick- Top
I used Nasons (Dupont second tier product) self etching primer.....available at most paint stores. Closely mimics zinc chromate greenish appearance.looking to buy some to paint the bird cage but with no luck at all my local paint stores. they said they stop selling that 15 years ago due to regulations. John Z gave me a link to aircraftspruce.com. they do sell it only in spray cans. am I buying true zinc chromate primer? what is every body else using ?- Top
Nason or DuPont each have a self etching primer used for corrosion protection over bare metal surfaces. Both are two part mixes, DuPont is 615s/616s, I'm not sure of the Nason product number. The Nason has a cheaper price tag. To get accurate color you may need to mix a little black tint in.- Top
SkyGeek sells it. Its real Zinc Chromate. Still used in aviation.Orr-lac 342 Green Zinc Chromate Primer - 11 Oz. Can - TT-P-1757A Type II
Steve Gansky
Newtown, (Bucks County) PA- Top
Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24- Top
