54 neutral safty swith lead - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 500
    Is this lead routed over top of the tranny and fastened to what? There is what appears to be a wire holder on right side of tranny by dip stick Thanks as always, getting ready for body drop soon.
  • Mike M.
    • May 31, 1974
    • 8409
    Re: 54 neutral safty swith lead
    if its like my 57 powerglide, and i believe the wire routes like the 57, then it goews back to the tranny X-member where it turns to the drivers side, then routes foreward to the switch. my 54 isn't handy to check it out, but i think, and think is the key here, that its like the 57 PG. to view the 57 PG neutral safty switch routing, get a 56-7 assembly manual. good luck,mike
    • Guy M.
      • November 1, 1993
      • 500
      Thanks Mike, thats very helpful
      • Chris S.
        • January 1, 2000
        • 1068
        Guy
        it passes along the front side of the trans crossmember
        there are two clips that hold it to the crossmember
        then it goes up the trans tunnel - passenger side
        there should be three clips (i think) that hold the wire up to the safety switch
        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
        1957 Corvette - FI 3 sp - Black and Silver
        • Guy M.
          • November 1, 1993
          • 500
          Thanks Chris, Im curious as to the clips at the cross member, do they just clip in place or fasten to the member bolts. I dont recall seeing anything there when I dieassembled. Those rivited clips under the tunnel must be for the wire? Thanks as usual, I want this to get torn out while driving.
          • Chris S.
            • January 1, 2000
            • 1068
            on the trans crossmember - there are two holes
            there are two clips that go in the hole
            one clip on the LH side
            one clip on the RH side
            The black wire goes in this clip
            The clips on the trans tunnel are riveted in - they are on the RH side.
            The wire goes in those clips on its way up to the relay
